What is blockchain and is it safe?: A guide to using crypto privately
Learn how blockchain works, what it's used for, and how to protect your data while using it
Blockchain is best known as the foundation of cryptocurrencies like Bitcoin and Ethereum. But the technology has broader applications, powering everything from decentralized finance (DeFi) to digital identity systems. At its core, blockchain is a distributed digital ledger, designed for transparency and immutability. Yet, as public and tamper-proof as blockchain may be, it isn't private by default.
In fact, many people mistakenly believe blockchain is anonymous. It's not. While names aren't attached to wallet addresses, every transaction is publicly logged — and can often be traced. That's why if you're engaging with blockchain tools or platforms, you need to take steps to protect your identity and metadata.
Bockchain explained: The building blocks of decentralization
A blockchain is a decentralized system that records transactions across a network of computers (or nodes). Each group of transactions is stored in a block, which is then cryptographically linked to the previous one. This structure makes the data resistant to tampering and ensures that once information is written, it’s permanent.
Blockchains rely on consensus mechanisms — like Proof of Work or Proof of Stake — to verify new transactions. Once a block is validated, it’s added to the chain, forming a public and permanent ledger.
Key features of blockchain include:
  • Decentralization: No central authority; relies on peer-to-peer validation
  • Transparency: All users can view the blockchain ledger
  • Immutability: Records can’t be changed once added
  • Security: Secured by cryptographic algorithms
How blockchain transactions work (step-by-step)
Let’s walk through how a typical blockchain transaction works to better understand both its transparency and its privacy limitations.
  1. Transaction initiated: You submit a transfer request (e.g., sending crypto)
  2. Broadcast to network: Your transaction is shared with nodes worldwide
  3. Validation: Nodes confirm it’s legitimate via consensus
  4. Block creation: The transaction joins others to form a new block
  5. Chain update: The new block is added to the ledger and cannot be changed
  6. Permanent record: Anyone can now view the transaction on the blockchain
So what’s missing? One crucial thing: privacy protections. Your transaction, timestamp, and wallet address are now part of a permanent public database, and anyone can track your financial activity forever.
The privacy problem with public blockchains
While blockchain ensures security and integrity, it falls short when it comes to user privacy. On most public blockchains (like Bitcoin or Ethereum), transactions are fully visible, including wallet addresses, timestamps, and transaction amounts.
Although names and email addresses aren’t directly visible, anyone with enough data — like IP addresses, exchange accounts, or browser metadata — can potentially de-anonymize your activity. Blockchain makes surveillance easier for anyone with the right tools: governments, advertisers, or even cybercriminals.
To use blockchain safely, especially for financial applications or Web3, you must actively protect your metadata.
How to use blockchain privately: Essential tips
Interacting with the blockchain doesn’t mean sacrificing your privacy. But taking the right steps requires different tools and practices. Here are key strategies for staying safe:
Use a decentralized VPN (like NymVPN)
A traditional VPN hides your IP address, but many still log traffic data. A decentralized VPN (dVPN) like NymVPN offers something stronger: metadata protection via a decentralized mixnet. It uses:
  • multi-layered (onion) encryption
  • multi-hop routing
  • added network noise (like cover traffic and packet mixing) to hide not just what you do, but how and when you do it.
Browse in private mode (but don't stop there)
Using a private browsing modes on your browser will help reduce stored data, but it's not enough on its own. Here's how to enable it:
  • Chrome: Ctrl/Cmd + Shift + N
  • Firefox: Ctrl/Cmd + Shift + P
  • Safari: File > New Private Window Private browsing blocks cookies and history, but your IP and traffic can still be tracked — so make sure to pair it with a VPN for stronger protection.
Choose a secure private browser
Switching to browsers designed for privacy is a good step forward from private browsing modes. Top options include:
  • Brave: Built-in ad/tracker blocking, supports Tor mode
  • Tor Browser: Uses onion routing to hide your location and activity
Using these browsers helps limit fingerprinting, tracking scripts, and data leakage, but they don’t protect data coming from other apps on your device like your wallet.
Avoid centralized platforms: DEXs and non-custodial wallets
Most people interact with blockchain through centralized services — like Coinbase or MetaMask linked to Google Chrome. These platforms often collect metadata, perform KYC checks, and can be hacked or subpoenaed.
To limit exposure:
  • Use non-custodial wallets where only you hold the keys
  • Prefer decentralized exchanges (DEXs) that don't require sign-up
  • Create multiple wallets for different purposes (NFTs, trading, donations)
The fewer connections between your wallets and your identity, the harder it is to trace you across the chain.
Blockchain use cases that require extra privacy protections
Some blockchain applications pose more privacy risks than others. Be especially cautious when interacting with the following:
  • DeFi platforms: Financial history is publicly accessible and could be traced back to you
  • DAO participation: Voting activity can be linked to your wallet and reveal affiliations
  • NFT transactions: Ownership and transfer history are easy to view on-chain
  • Web3 identity: Logins can reveal wallet usage across multiple platforms
  • Smart contracts: Automated actions can leak patterns and behaviors
For these use cases, privacy tools like NymVPN and secure browsers are essential to reduce your visibility.
Why blockchain doesn’t equal anonymity
Let’s be clear: blockchain is pseudonymous, not anonymous. Anyone can look up your wallet and see its activity. If they ever link that wallet to your identity (via a purchase, exchange, or login), your entire transaction history becomes public knowledge.
This lack of privacy can be risky for:
  • Activists or journalists working in hostile regions
  • Users storing or moving large sums of crypto
  • People involved in controversial DAOs or decentralized projects
  • Anyone who values financial discretion
Blockchains don’t forget – but you can limit what they learn with the right tools.
How to get started with blockchain and crypto while protecting your privacy
Want to use blockchain more safely? Here’s a beginner-friendly setup that balances access and privacy:
  1. Download NymVPN to protect your IP and metadata
  2. Use Brave or Tor browser to block ads and trackers
  3. Create a fresh, non-KYC wallet
  4. Access decentralized apps through privacy browsers only
  5. Avoid linking personal emails or real names
Privacy takes a few extra steps, but it’s worth it if you care about digital sovereignty.
Blockchain: Frequently Asked Questions
Yes. Blockchain ensures data cannot be altered or deleted, making it secure. However, transactions are publicly viewable, which means your activity is visible unless extra privacy tools are used to protect your identity.
It’s possible, but not by default. You’ll need to use a VPN, privacy-focused browser, and a non-custodial wallet—plus avoid linking personal details—to prevent others from tracing your blockchain transactions back to you.
A decentralized VPN like NymVPN protects your IP address and metadata using multi-hop encryption and cover traffic. It prevents even powerful adversaries from monitoring your blockchain interactions or tracking your identity online.
Private blockchains can limit access but often log user activity and are controlled by centralized entities. They may enhance security for enterprises but don’t necessarily offer better personal privacy than public blockchains with strong protective tools.
Yes. Smart contracts publicly record actions and transactions. If linked to your wallet, they can expose your behaviors or preferences. Use privacy layers like NymVPN and avoid using the same wallet across different platforms.
Communications Lead
12 mins read
What is Decentralized Finance (DeFi)? A privacy guide to the world of crypto
Discover how decentralized finance works, how it compares to traditional banks, and what you should know before diving in
