How to adjust SafeSearch settings for Google & other platforms
Choose the content you want to see – not algorithms
SafeSearch is a built-in filter used by search engines like Google, Bing, and YouTube to hide explicit content. While useful in some cases, these filters can also reinforce surveillance-based tracking and behavioral profiling — especially when you're not using privacy tools that protect your metadata.
Here’s how to adjust these settings so you’re in better control of the information you see.
How SafeSearch filters work
SafeSearch uses algorithms that classify content based on tags, metadata, and reports. These systems rely on behavioral data, meaning the more you search, the more the engine refines your content visibility — and your user profile.
This often means sharing more data with the provider in exchange for “cleaner” results.
Is SafeSearch a Privacy Tool?
No. SafeSearch is a filter, not a privacy protector. It hides content from you — but it doesn’t hide you from your ISP, browser, or search engine. Every click, query, and toggle feeds into data mining pipelines that target you with personalized ads and recommendations.
Enabling or disabling SafeSearch on Google
  • Navigate to the Google homepage and log into your account
  • Click on Settings at the bottom right corner
  • Select Search settings
  • Check or uncheck the box next to Turn on SafeSearch to enable or disable the feature
  • Click Save to apply changes
  • Open the Google app
  • Tap on your profile picture in the top right corner
  • Select Settings
  • Tap on SafeSearch
  • Toggle the switch to turn SafeSearch on or off
Managing SafeSearch on Bing
  • Go to the Bing homepage and sign in to your account
  • Click on the hamburger menu (three horizontal lines) in the top right corner
  • Select Settings > More
  • Under SafeSearch choose between Strict, Moderate, or Off
  • Open the Bing app
  • Tap on the profile icon
  • Select Settings
  • Tap on SafeSearch
  • Choose the desired SafeSearch level
Configuring SafeSearch on YouTube
  • Navigate to YouTube and log into your account
  • Click on your profile picture in the top right corner
  • Select Restricted Mode from the dropdown menu
  • Toggle the switch to enable or disable Restricted Mode
  • Open the YouTube app
  • Go to Settings > General
  • Toggle Restricted Mode on or off
Implementing SafeSearch
  • Open Settings and tap on Screen Time
  • Select Content & Privacy Restrictions and enable it.
  • Tap on Content Restrictions > Web Content
  • Choose Limit Adult Websites to enable SafeSearch across browsers
  • Install and open the Google Family Link app
  • Select your child's account
  • Tap on Manage settings > Filters on Google Search
  • Toggle SafeSearch to on
Safe Search: Frequently Asked Questions
No. SafeSearch filters content from your view but not your identity from the search engine. Your queries, clicks, and behavior are still logged and tied to your profile unless you use privacy tools like mixnets, decentralized VPNs, and private browsers.
Yes. While SafeSearch can be enforced by network administrators (like schools or workplaces), most users can disable it manually in search settings — unless it’s locked at the device or DNS level.
Go to Google Search Settings, uncheck Turn on SafeSearch, then scroll down and click Save. Note: You may need to log in to your account to change settings.
Yes. SafeSearch can be controlled through browser or app settings on both iOS and Android. However, mobile carriers and public Wi-Fi networks may still apply their own filtering.
For real online privacy, use a Noise Generating Network like NymVPN to anonymize your metadata, combined with a private search engine like DuckDuckGo. This shields both your queries and your digital fingerprint.
SafeSearch is just a filter
It doesn't protect your privacy.
Benjamin Nemeroff
Casey Ford. PhD
Technical reviewer
Nym Communication Blog Image
How to change your IP address on any device or OS
Changing your IP address can help you enhance security, access restricted content, and troubleshoot network issues.
How to clear cache on iPhone
Boost speed, free up space, and stay untraceable
What is my IP address?
How anyone can see where you are and track what you’re doing online
