When it comes to online privacy, using a Virtual Private Network (VPN) is often one of the first suggestions. But not all VPNs offer the same level of protection, and understanding how they work is crucial if you truly care about minimizing your digital footprint.
In this post, we’ll dive deep into how traditional (centralized) VPNs function, explore the concept of decentralized 2-hop VPNs, and unpack the different architectural choices, especially through the lens of the WireGuard protocol.
The traditional VPN model: A single point of trust
What is a VPN?
WireGuard with NymVPN: FAQs
AmneziaWG incorporates randomized padding, leak prevention, and router rate shaping—specifically designed for decentralized mixnet integration.
Yes—Nym provides open-source SDKs and the AmneziaWG protocol stack for developers to integrate decentralized WireGuard environments into dApps, P2P networks, or VPN tools.
Key exchange is federated: entry-exit gateway pairs authenticate via zk‑nyms, and routing credentials are rotated frequently to maintain unlinkability.
Yes—AmneziaWG builds on WireGuard's NAT traversal features and adds IPv6-aware routing and fallback node discovery for robust decentralized deployments. Learn more about the difference between IPv4 and IPv6.
Decentralized routing adds minor latency and bandwidth variability, but thanks to NymVPN's decentralized WireGuard routing protocol, the Fast mode still remains competitive with centralized VPNs in multi-hop architectures.
Ania M. Piotrowska, PhD
16 mins read
What Is a VPN tunnel? How encrypted connections keep you private
Secure your digital content and communications with VPN tunnels
