The Nym network monitor is going decentralized
Network monitoring is the system that measures how well each node carries your traffic. It is moving into the hands of the community, and we are inviting operators to help run it.
Each decentralized part of the Nym infrastructure, from routing to zero-knowledge payments, is designed to protect your privacy. To ensure network performance, Nym has run a smaller set of coordination functions centrally. Until now, running them this way has been a deliberate, temporary measure for a maturing network, and each has a clear path to being handed over to the operator community.
The network monitor is one of these functions that has been run by Nym, just as network monitoring and metrics are currently run centrally by Tor. The network monitor measures how well each mix node carries traffic to determine which nodes route traffic, and how rewards are shared. At Nym, we've never been happy with centralized monitoring, so earlier this year we published a peer-reviewed design in EuroS&P 2026 to decentralize it.
Monitoring the network from a central vantage point has allowed us to better support the network as it grew. Now that it has reached maturity with over 900 nodes and operator governance, we're taking the step of decentralizing measurement. The code is written, merged, and public, and it is rolling out in phases across our next mainnet releases.
Decentralized network monitoring accomplishes two crucial things:
  1. Taking measurement out of any single party's hands
  2. Improving the accuracy of node-performance measurements via many independent participants corroborating from different network perspectives
And we want you to help us do it!
Help run Nym's network monitor
Measuring the network will be a role community operators can take on, so we're inviting you to join us as network monitors.
How to join
Simply fill out the form to register your interest, and our team will follow up with technical help to let you install the necessary code from our GitHub.
If you want a direct hand in maintaining the Nym network, this is where to get involved.
New here? Learn how to set up a Nym node and join the operator community.
What you should know
There are a few things to know about this beta program:
  • Monitoring will be an on-chain role.
  • Each network monitor runs a fleet of monitor agents, each with a persistent on-chain identity. Which agents may measure is fixed by the on-chain registry.
  • For now, a permissioned multisig authorizes who may measure, and network monitors must apply to join and then be voted in by a majority of the existing network monitors.
  • The system will later transition to permissionless network monitoring, eventually letting the clients themselves measure and report network quality.
What’s a network monitor, and why is it necessary?
For a mixnet like Nym's to work for the people who use it, the servers routing your traffic have to be reliable. But a node cannot be trusted to grade itself. A node that quietly drops, delays, or mishandles traffic could simply report that it is perfectly healthy. So the network needs an independent way to see how each node is really performing.
That is what the network monitor does. It sends test traffic through nodes and checks what comes back, producing a performance score for each one on how reliably it carries traffic. These scores feed two consequential decisions:
  1. which nodes are chosen to route traffic each cycle in what we call the active set
  2. how rewards are shared as a result of it
Performance scores and stake: How nodes are chosen
Each cycle, the network picks the mix nodes that will route people’s traffic. A node's chance of being picked depends on (1) its stake and (2) its performance score. The latter score dominates: selection weight multiplies a node's capped stake by its performance raised to the twentieth power. So a node at 90% reliability counts for only about 1/8 of a perfect one (0.9²⁰ ≈ 0.12). Stake still matters, but only up to a saturation cap, after which more stake buys no more weight.
Because the score carries that much weight, the measurement behind it has to be trustworthy — this is why Nym has taken up the network monitoring role since launch.
Measurement should not be done by one party alone
Before we even built the network, in the Nym whitepaper we argued that network monitoring must have no single point of failure as it is "a highly consequential network function that determines who gets rewarded and how much." Still, as there were early attempts at sybil attacks on Nym, running that monitor ourselves made sense while the network was still immature and growing. However, any centralized network monitor was always meant to be temporary, and we have been working hard on a design to decentralize it.
We believe that this job should not rest with any one party, Nym included.
Separately from who runs the monitor, the current measurement method has a weakness an attacker could exploit. Through responsible disclosure, researchers documented one concrete scenario showing how measurements could be gamed to change which nodes get rewarded. So let’s take a look at it.
Cao and Green’s analysis
A scenario like this was well documented in "Analysis and Attacks on the Reputation System of Nym," by Xinmu Cao and Matthew Green at Johns Hopkins (2026). It reached us through coordinated disclosure: the authors shared it before publishing, we acknowledged it, gave feedback, and sped up our development in response.
To summarize, the current centralized monitor (NMv1) starts by singling out a set of nodes it treats as reliable. To score any other node, it routes test traffic through some of those reliable nodes together with the node under test, and checks how much arrives. If a packet goes missing, the blame falls on the node under test.
Cao and Green's simulated framing attack exploits the weight of that score. An adversary first runs well-behaved nodes to get some of them into the trusted set through which the monitor measures. Once inside, they selectively drop packets while measuring honest, high-reputation nodes, so the blame and the penalty land on the honest ones. That pushes honest nodes out of the active set, letting the attacker's own nodes take those slots far more cheaply than buying in with stake. It also takes luck: only a small set of nodes is chosen to measure others each cycle, and the attacker must win one of those slots against many honest ones.
To be clear, Cao and Green’s attack was modeled and simulated, not run against the live network. And it is both an economic attack and one that bears on user anonymity, since over long periods of time an adversary could use this technique to try to capture an entire path. That is very hard to do, however, since traffic is spread randomly across many different paths.
Still, this attack could allow malicious nodes to slowly infiltrate the network. The attack is really a weakness in how nodes are scored by the centralized NMv1. That is an important reason to upgrade the network monitor to NMv3.
We encourage researchers to reach out to the Nym team, as we can often help them. For example, Cao and Green were not aware of our long-standing design to decentralize network measurements, Decentralized Reliability Estimation for Low Latency Mixnets, before contacting us.
What is changing
Decentralizing the monitor means two changes: how nodes are measured, and who does the measuring.
Measure each node in isolation
The new monitor, NMv3, measures each node directly: the test path is just the node under test and the measuring agent, with no chain of "reliable" intermediaries for an adversary to slip into. This removes the lever the framing attack relies on. Before, an adversary only needed one of its nodes inside that trusted set; now there is no such set to infiltrate.
Decentralize who measures
Measurement moves onto an on-chain registry of authorized agents: a multisig authorizes orchestrators and monitoring agents, each with a persistent on-chain identity, and the registry sets which agents may measure node quality. Their results are combined into a median, so no single monitor's number decides on its own.
Importantly, this change makes the measurement better, not just less centralized. One monitor is a single vantage point. When many independent agents corroborate one another, a node that looks poor from one agent's path but fine from the rest no longer skews the score. This holds to the extent the agents are genuinely independent and measuring from different network perspectives.
What this does, and does not do
Besides decentralization, we have added per-node direct measurements of nodes in order to stress test their performance. As each score becomes a median across many independent probes, an attacker would have to control more than half of them — and the more it's spread across independent measurement authorities, the harder the attack gets.
For now, these per-node stress tests are still recognizable as tests, unlike measurements that run across a whole path — which is why the live score still pairs per-node stress testing with full-path measurement in the style of NMv1. Removing that tell is exactly what our peer-reviewed EuroS&P 2026 design does: it uses a verifiable random function to generate measurement packets that a routing node cannot distinguish from ordinary client traffic, so a node can't selectively serve probes while dropping real users.
There is still work to be done to fully decentralize measurements by having the network monitors be end-user clients and share these results in a peer-to-peer fashion with continuous measurements. This work is already underway, and will be announced when completed.
Notes on rollout
The per-node agents, the registry, and the contract have been coded and are ready to go. The code is public and you can read the NMv3 network monitor on GitHub. Today, the Nym API's live score still combines NMv3 "stress test" per-node values with NMv1 scores that measure entire paths.
Once performance lives on-chain, multiple Nym APIs can serve the same measurements to every client, removing another point where one party's view would be authoritative. So this is permissioned decentralization for now: a multisig decides who may measure, which removes the single-monitor chokepoint but is not yet an open, anyone-can-measure system. Making network probes indistinguishable from normal traffic and opening measurement beyond a vetted set is the next phase.
Making Nym decentralized all the way down
Decentralization is an ongoing process, not an absolute. It should be done with concrete goals in mind, and from the beginning ours has been to build an anonymous network that works for the people who use it.
Decentralizing measurement is one step in that: it reduces how much any one party, Nym included, can shape the network's view of itself, or quietly capture it. Having many independent parties measure network quality and corroborate rather than trusting should also make that view more accurate.
And it is something you can take part in directly.
Want to join us?
What is decentralization?
Understanding principles and technologies for freedom, power regulation, and autonomy today
