How VPNs impact internet speed (and why it’s usually not a big deal)
How VPNs affect connection speed — and why privacy still comes first
Using a Virtual Private Network (VPN) encrypts your internet traffic and routes it through a secure server before it hits the open internet. This protects your privacy, but it can also introduce some speed changes.
Here’s the real story: Most of the time, if you’re using a reputable decentralized VPN like NymVPN, any slowdown is barely noticeable. But some factors do play a role.
What is a VPN?
VPN speed Frequently Asked Questions
It can — but usually only slightly if you use a strong VPN provider. Choose a server close to your location and use a fast protocol like WireGuard to minimize any lag.
Pick a server geographically closer to you with lower user load. Many VPN apps, including NymVPN, show real-time server status to help you decide.
Server congestion, network routing issues, or temporary ISP throttling can create inconsistent speeds. Switching servers or protocols often fixes the problem.
Yes. Free VPNs often have overcrowded servers and outdated infrastructure, leading to much slower speeds and weaker encryption.
For consistent privacy protection, yes. With a privacy-focused service like NymVPN, you can stay protected without sacrificing reliable internet performance.
Benjamin Nemeroff
Casey Ford. PhD
Technical reviewer
12 mins read
Nym Communication Blog Image
How to change your IP address on any device or OS
Changing your IP address can help you enhance security, access restricted content, and troubleshoot network issues.
