We like to say that Nym is more than VPN: it’s first of all a L0 anonymity network capable of protecting network traffic on a range of digital services and platforms. And it’s open source and ready to be built on.
Here’s an exciting case in point: Edge Wallet has now natively integrated the Nym mixnet as an advanced privacy feature. With the mixnet, you can now protect the metadata of your financial transactions without ever leaving your wallet.
The Nym mixnet explained
The Nym mixnet is a decentralized, 5-hop network designed to anonymize user traffic by obscuring the metadata trail with noise. What is noise exactly? It’s a series of techniques that serve to hide the signal of who you are and what you’re doing, even against advanced AI surveillance techniques.
  • Identical packet sizes shield your data from being identified
  • Cover traffic sent with your real data packets helps hide your traffic patterns and frequency
  • Packet mixing shuffles your packets up with those of other people on the network to obscure your routes
  • And timing delays protect you against traffic analysis along the way
The Nym mixnet is configurable directly in your Edge Wallet.
  • Go the Menu *** > Options > Privacy Settings
  • Select the asset you want to use the mixnet and toggle it on
  • Transactions with this asset will now be routed through the Nym mixnet from Edge
Note: Edge advises to use the mixnet one asset at a time to reduce latency, with performance optimization to the feature in the pipeline.
What’s next for Nym & Edge
Following Edge’s integration of the $NYM token into their suite, the mixnet integration continues what’s proving to be an exciting partnership between the two teams.
On Nym’s side, we’re working on some important optimizations of the mixnet routing infrastructure that will significantly improve performance, speed, and cryptography. Check out Nym’s 2026 roadmap for everything Nym is doing this year to make the internet and crypto private by default.
Thanks to the hard work of Edge and Nym devs, Edge Wallet now joins the avant-garde of crypto privacy protections alongside privacy coins like Monero and Zcash. The question is, which Web3 projects are next to join their ranks to build the next-gen privacy stack fighting digital surveillance, from communication to finance?
Communications Lead
