You can now swap $NYM via Edge Wallet thanks to the Edge team’s integration work.
Edge Wallet is a non-custodial, no-KYC cryptocurrency wallet for mobile that gives users ownership over their digital assets while embodying digital privacy principles.
Unlike custodial wallets which hold your keys and control your funds on your behalf, Edge Wallet empowers you through self-custody: you control your private keys and data. These keys are encrypted on your device, never stored or accessible by Edge itself or any third party. This means only you can spend or transfer your crypto.
This makes Edge Wallet a Nym-trusted ally in the privacy stack ecosystem. Having $NYM easily available to Edge users is the first step in what will become a cool collab between our teams, so stay tuned for more!
Why Nym likes Edge
Blockchain was never designed with privacy as part of the infra. As surveillance systems get supercharged by AI, how we store, manage, and transact with cryptomatters more than ever.
Edge Wallet embodies the principles that cryptocurrencies were built on: autonomy & decentralization. Whether you’re sending a payment, swapping assets in-app, or simply storing crypto for the long term, Edge provides a secure and private UI that keeps you in control.
What makes Edge Wallet a trusted crypto tool
Ensuring privacy in cryptocurrency isn’t simple: it requires protecting your transaction history, shielding your identity from linkage, and ensuring that third parties have no access to your keys, data, or funds. All of this is increasingly vital as blockchain analysis techniques grow more sophisticated.
Here’s what makes Edge Wallet stand out:
First off: No KYC
No need to de-anonymize yourself to tech companies and any surveillance watching them.
True self-custody
With Edge, you generate and manage your own keys locally on your device. That means no centralized server has access to your private information or transaction history.
Decentralized, client-side encryption
All sensitive data — from private keys to login credentials — is encrypted on your device before anything touches the network, protecting your financial footprint from unnecessary exposure.
Separate keys per wallet
Edge uses distinct, independent keys for each wallet under your account, which reduces metadata linkage across addresses and wallets, helping protect against clustering or identity inference from on-chain activity.
These technical design choices reduce the number of privacy leaks that can occur when intermediaries manage your keys or associate transactions with identifiable user profiles. While on-chain privacy techniques like stealth addresses or zero-knowledge proofs are specific to certain protocols and privacy coins, secure key management and minimized metadata exposure remain foundational to preserving privacy in any crypto transaction.
New features for all circumstances
Check out Edge’s new Duress Mode, a stealth login feature that lets you enter a decoy account using a separate PIN in case of an emergency. This hides your real wallets and balances without indicating that you’re using the decoy.
Edge’s Privacy Manifesto
Not all wallets make privacy a central priority. Unfortunately, many focus on convenience at the cost of user anonymity. Edge Wallet’s Privacy Manifesto sets it with principles designed to limit data exposure and resist association of user identities with blockchain activity.
But Edge’s technology speaks for itself:
  • Independent keys per wallet help prevent correlation of all your assets under one master identity
  • Minimized metadata collection means Edge does not collect or retain transaction metadata that could be used to profile users
  • No linkage of external exchange activity to your identity, even if the wallet integrates swap features
  • And no KYC!
Such privacy commitments matter in a world where digital surveillance is increasingly pervasive, and made easy by Web2 applications and centralized financial platforms. Privacy needs to be both an ethos and a design principle. Financial sovereignty and data protection hang in the balance.
A trusted Nym partner
No single tool can solve every privacy challenge on its own. For truly anonymous and secure crypto use, you should think beyond just where keys are stored to how transactions and device communications travel across the internet. You need to build a privacy stack of tools.
  • Edge Wallet ensures that your keys and on-chain metadata are controlled and encrypted at the user level.
  • NymVPN and the Nym mixnet protect your network layer privacy, anonymizing your IP address and obscuring patterns of communication that could tie your on-chain activity back to you.
Even the best wallet cannot conceal who is connecting to which blockchain nodes or how your device communicates with servers. Network-level privacy tools like NymVPN ensure that your internet traffic is not linkable to your device or identity, further reducing the potential for surveillance or profiling based on crypto usage.
Used together, Edge Wallet and L0 anonymization tools like NymVPN create a more resilient and private approach to managing digital assets. Privacy stacks like this are the future of ensuring decentralization and autonomy for blockchain technology and private crypto.
